greende
Jul 15, 2016Explorer II
You should check power going into the circuit board and power out to the heating element as well. I recently had the same thing happen but only intermittently. I have reason to believe that relay is sticking. I always have 120V power into the circuit board but none out when the element doesn't work. Then, spontaneously, it will work again. If it keeps up or gets more frequent, I will have to replace the lower (outside) control board.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 14, 2026
