enblethen
Jul 19, 2013Nomad
When refer set to auto, it will seek 120 volts AC first.
The GFCI receptacle will trip if it sees an unbalance between the phase conductor and thhe neutral.
You would need a meter set to resistance to measure the element. Disconnect the element wire from the circuit board. then measure between wire and a good ground. Meter should be set on a high resistance scale. Any reading to ground can trip the GFCI receptacle.
14 gauge 50 foot is a little light. Remember that there is other 120 volt loads. The converter is one.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 14, 2026
