AZ_T_T
Jul 29, 2014Explorer
Regulator Issues?
This weekend while dry camping one of my 2 propane bottles ran out of gas. When I opened the second bottle and turned the regulator to the other bottle we had no pressure in the system. The bottle was completely full. Thinking the regulator switch (which is an auto switch) was bad I changed the full bottle to to position of the empty bottle and still no pressure. I had a little 2 gallon propane tank to use with a weed torch so I hooked it up and also nothing.
Now I'm thinking it is vapor locked so I unhook both bottles and turn the stove on to clear the vapor lock. After that I hook up the large empty bottle and full bottle, still no pressure. Last resort I re-hookup small 2 gallon bottle and finally I have pressure. I switch to the large bottle still nothing, so I switch positions still nothing from large bottle.
Now I think I have a bad bottle so I hook it up to the weed torch and it's fine.
After all of this I ran the fridge on the small bottle. Went to install the large bottle to drive home (the little bottle would just flop around) all of a sudden it now will pressurize the system. Everything is normal.
Has anyone else ever experienced something like this? If so what was the culprit?
