- BB_TXNomadI removed the cracked and peeling decals on the front and rear of my 5er. Sides still look good.
Started with a heat gun and plastic scraper. Worked pretty well on some decals that were in better condition. But the ones really cracked were very hard to get off, coming off in very small pieces. Bought a 3M eraser wheel. Decals came off easier with the added benefit that a lot of the old adhesive came off with the decal material. But it does take a good corded drill to turn the eraser wheel. I supppse a cordless would work but you would probably be recharging the battery every few minutes as it works it pretty hard.
With either method there will be adhesive material left on the surface requiring some type solvent to thoroughly remove it. I used 3M Adhesive Remover. What worked for me was to use an old towel and wet it with solvent. Then holding the towel below a section of adhesive, I would squirt a stream of solvent across and above that section letting the liquid “sheet” down over the adhesive and soak into the towel. Then use the towel to wipe the adhesive off that section. Then move on to another section working small sections at a time.
The areas that had been under the decals were nice and shiny showing the outline of the old decals. The other areas showed signs of oxidation. But for me that was great. I managed to get exact replacement decals and the outlines made placement of the new decals easy.
I used the “wet hinge” method of installing the new decals. (Google it). And found that using a wet towel to smooth the decals and squeeze out the water worked better than a squeegee. - Super_DaveExplorerI can't install a foot long decal without bubbles. When the time comes, it's going to be a graphics or body wrap company doing all my decal work.
- Fisher_BillExplorerYes I'm also in the same boat, the stock graphics are drying off the surface and I would rather go all white but of course the removal will show the change in color tones.
We have a 2010 so not that old but the nose and sides are peeling an inch every two or so years, unit came from CA and looked like it baked in the sun... - laknoxNomadThere are some chemicals that people use, but the most frequent method seems to be a heat gun and patience.
Lyle
About Fifth Wheel Group
19,021 PostsLatest Activity: Jul 26, 2025
