walker2413's avatar
walker2413
removing batteries for winter.
I live in a fairly cold climate and winter seems to have been hard on my batteries. This fall, I am planning on taking out the 2 – 6 volt deep cycle batteries in my fifth wheel and storing them in the basement on a piece of plywood for the winter. When I take them out, I plan to put the positive battery wires in a plastic bag and taping it up for insulation. I am planning on putting the negative wires into another. The purpose of the bags is so that these terminals cannot touch each other and cause a short circuit. My question is this: “With no batteries attached to the system, can I still plug the trailer in and run most systems on ac? I like to plug in an electronic rodent repelling device. I am just nervous of how the built in trailer charging system will behave with no batteries. My next question is this: while storing the batteries in the basement, if I hook them up in series, is it al-right to put a 12 volt battery maintainer on these batteries?
Thanks,
Bill W
  • I would think the house current should still work without batteries. Someone else should know that. You can keep the two 6 voters in series plugged in to a maintenance charger. Sound like you are doing this correctly.
