rjsurfer's avatar
rjsurfer
Removing Dometic stove/oven
I'm thinking of ditching the old WFCO converter for a better one but I noticed the converter is under the stove behind the breaker panel. Can the converter be changed out by just sliding the breaker box forward?
Or, would removing the stove be better, I could also access all the wiring more easily and check out how the cables are laid out.
Ron W.
  • There's usually a solid piece of plywood under the stove.
    Generally speaking, the fuse/breaker box can be pulled out enough to access the converter.
