Durb
Feb 22, 2016Explorer
Removing heavy hitch from truck
This has worked well for me so I thought I would share. I leave my hitch hooked to the 5er, remove the rail pins and use the landing gear to lift the hitch out of the truck. I use a 500# hydraulic table from Harbor Freight ($136) which happens to fit the hitch perfectly. I jack the table until the entire weight is off the kingpin then unhook the hitch. Lower the table to ankle height and roll into the garage. No lifting, no climbing.
I got a 99 dollar lift from Harbor Freight, I took a little extra fabrication to toughen up the mounting but it makes short work of the hitch and the 300lb generator.
[IMG]http://i269.photobucket.com/albums/jj53/snoking1127/IMG_20151012_081603969_zpsildax7s2.jpg" width=640>
