- Traveler_IIExplorerJust wondering why you are removing the silicone? Ours has clear silicone on all the exterior seams and it’s holding up great.
- benb21601Explorermineral spirits. available at walmart. will dissolve it and not hurt the fiberglass. can take a little elbow grease tho.
- SoundGuyExplorer
TakingThe5th wrote:
I just installed a new Maxxfan and the instructions specifically called for unpaintable silicone caulk. My previous fan recommended Dicor-like caulk. Hmmmmm
Curious. :h I wouldn't ever let silicone caulk near my camper, particularly when products like Dicor lap sealant designed specifically for the purpose are so readily available and have a proven track record. - TakingThe5thExplorerI just installed a new Maxxfan and the instructions specifically called for unpaintable silicone caulk. My previous fan recommended Dicor-like caulk. Hmmmmm
- Old-BiscuitExplorer III
SoundGuy wrote:
nano wrote:
In your experience, what works the best for removing silicone caulk?
A 2013 rig shouldn't have silicone caulking on it anywhere unless it's been added after the fact by yourself or someone else. Removing it successfully is one of several reasons silicone caulking shouldn't be used on the exterior of any recreational vehicle, the stuff is darned near impossible to get rid of and tougher still to get proper caulk to stick the surface that previously had silicone applied to it. :M
That's why you have to use a solvent designed for silicone. Silicone leaves behind a residue that has to be cleaned off before any new caulking can be applied.
Agree that a 2013 RV shouldn't have any silicone. - SoundGuyExplorer
A 2013 rig shouldn't have silicone caulking on it anywhere unless it's been added after the fact by yourself or someone else. Removing it successfully is one of several reasons silicone caulking shouldn't be used on the exterior of any recreational vehicle, the stuff is darned near impossible to get rid of and tougher still to get proper caulk to stick the surface that previously had silicone applied to it. :M - SHExplorer
- Wet_CoastExplorerHiya, My unit is a 1987 Okanagan with petrified caulk. I have started going around and redoing all of the seams. I have used something available at a local Plastics shop called "Contractor's Solvent".
The stuff is amazing. It expands the silicone and the stuff comes out of seams all by itself. It will remove the RV caulks as well. Get yourself some of the plastic bondo scrapers and other plastic implements of destruction. Home Depot has cool disposable silicone tools as well.
It may take some experimenting to get the right tools, but the solvent works great for the initial work. Albeit, I have had to use a little help with a heat gun in places. Final cleanup is elbow grease and perhaps some acetone. - midnightsadieExplorer IIa one edge razor blade ,
About Fifth Wheel Group
19,023 PostsLatest Activity: Aug 11, 2025
