jimmyfred
Sep 26, 2016Explorer
Jack_Diane_Freedom wrote:
One of the things that you must do is install the window A/C so that their is adequate water drainage away from the slide out. You may even want to install a drainage tube.
............Thanks ! The mfger instructions show the correct amount of 'Drop' the rear portion of the case should have for the case to have adequate drainage . , jf
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
