glazier's avatar
glazier
Explorer II
Jul 30, 2013
Removing the Hitch
I have read many post on different options to remove the heavy hitches from the beds of trucks, I wanted to show how I do it. My garage door is 12' x 14' and when the door is up there is just no way to attach something above it with the truck setting there. My solution was to make a light weight beam to attach a hoist.
  • I just pull the pins on the rails while hooked to trailer, hit the jacks and pull up, leaving it hanging on the kingpin till spring. Quick, easy and out of the way.
  • Never gave it any thought. Just hopped up into the bed of the pickup, carried hitch to tailgate. Hop out of truck and carry hitch into garage
  • I bought a small winch from Harbor freight and installed it on the ceiling of my garage. Back under it...raise the hitch...pull out...lower the hitch onto a "piano mover", and store it out of the way. Takes 5 - 10 minutes and zero strain.
  • Water-Bug wrote:
    I use the FEL (Front End Loader) on my CUT (Compact Utility Tractor).
    I have a Kubota, and a Hyster Fork Lift parked next to that building the fiver is in. I was posting this for a simple solution to folks that may not have access to those items
  • Fortunately, I am still able at my age (71) to install and remove my B&W hitch from my truck.
    It is stored on a 4 wheel dolly.
  • I use the FEL (Front End Loader) on my CUT (Compact Utility Tractor).
