dave17352
Oct 14, 2013Explorer II
TucsonJim wrote:
Do not let vapors release from the tank and drift through the garage, especially if you have an ignition source nearby such as a water heater. Tightly plug up hoses and openings in order to prevent vapor release. Make sure all electrical devices are shut off and unplugged or removed from the area. This could include items such as CD players, clocks and radios. Disconnect the negative battery terminal before you get started. Have a couple of fire extinguishers available that are rated for Class B fires. Do not use a garden hose to fight a gasoline fire, it will just spread the flames. Just remember, if you have a fire in this situation, you'll not only lose your vehicle, but also potentially your house.
Keep the tank level when bringing it down to prevent spills. If you do have a spill, have a plan on how you'll react to contain the spill.
When we were changing fuel pumps or tanks when I was a mechanic, we'd frequently tie a rag around our wrist. When you're working under the vehicle, this was a real help if gas started to run down our arm. As long as the run off is not too heavy, the rag will keep if from running all the way down your arm to your arm pits and torso.
Wear eye protection with side shields. If you should happen to get fuel in your eyes, I'd recommend that you have a method to wash your eyes available for immediate use. Remember, that you will not be able to see where you are going in order to deploy the eyewash.
You must have been a boy scout. Always prepared! You thought of everything. Great Post.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
