Randu
Jun 30, 2015Explorer
If the disc brakes were factory installed then you may have sealed bearings as that was a standard with many factory installed systems.
Dexter had Rotors that were separate from hubs so remove caliper, remove rotor and then your ready to remove hub. Kodiak has rotor /hub all 1 piece. No mounting or back plates need to be remover. This is based on 8000# axles as I have owned both. Kodiak much easier to work on without busted knuckles. Randu
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
