rtaylor0830 wrote:
Hi this maybe a stupid question but when you repack your bearings how much grease do yo put on the races and spindle. Imake sure the bearings are packed very good and put a little grease on the races but I heard it does not have to be glob bed on for a land trailer is this true. I have the grease fittings on the hub but I do not like using them because I am scared of blowing the seal.
Dr Quick wrote:
When I repack bearings I coat the "races" and "spindle" with a light coating grease before assembly. When trailer is moving all the grease stays with the bearings, so as long as bearing are packed right, there should be no problems.
I agree. And I also agree that the quick lube hubs are not anything that you should use. For the same reason you cite here. And for the fact that before the grease gets on the bearings, you need to pump a whole lot of grease into the hub cavity. And that grease in there does absolutely no good for anything. Just a big waste of grease, time, and money.
