donn0128
Jun 12, 2013Explorer II
Why? Venture has been great to work with. Parts are reasonable and my landing hear is done well for 7 years until this year when I rebuilt one leg. BTW I also converted to a dual motor setup last year. Best thing I ever did for the outside. I also added up limit switches and heavy duty reversing relays.
You can buy the dual motor setup from Venture. In reality all you need is the curb side powered leg which is not too expensive. Pop the caps off the tops of the legs and get the part numbers. When you call them give then the numbers and tell them you want a curb side powered leg assembly. Then all you have to do is remove the curb side leg and install the new one when it comes.
About Fifth Wheel Group
