GOCK wrote:
OK, pump stopped pumping. thought it was out of gas so I filled the tank up. Still no luck. Took out the gears, tried sanding (I'm sure I ddi that wrong) put it back together and still didn't work. Loosened bolts and tried again. No luck. Removed cover and gears, tried to pump and nothing. I'm sure I'm in over my head now. Any suggestion's?
This is on a weekend warrior and I have not been able to track down a fuse.
Thanks!
There are two fuses for the fuel pump station. The first one is in the externally accessed fuse panel where you have electrical service. The second fuse is in a covered in-line holder near the pump motor.
