It finally happened to me too. But mine started out as a leak. Thought it was the rubber line between the tank and pump so pulled it off and it is JUNK! F'n ethanol! Thought that was it, reassembled and leaks even worse. Upon closer inspection see it is dripping from the pump housing. Took it off and on the bench see a "weep hole" so deduce the seal is shot; F'n ethanonl. So I've ordered a new gear set, new gaskets and seal. Total parts $35.00
Now the bright spot; ordered the parts through Gercsey/Frost Engineering:
Frost Engineering Service
3625 W. MacArthur Blvd.
Suite 306
Santa Ana, CA 92704
714.549.9222
714.979.8240 fax
email:
[email protected]Highly recommend them, family owned and extremely easy to work with.
