MaxAZ's avatar
MaxAZ
Repairing fuel station pump
My pump wasn't turning on so I loosened up a couple of bolts on the gear cover panel and then it started pumping again. Wasn't leaking or anything after loosening the bolts but I investigated some more and removed the gears. I noticed that the gears had been rubbing pretty good on the cover panel so I got out some sand paper and sanded down the gears so they weren't so wide. After I put it all back together it was working pretty good at first but then slowed down and wouldn't run unless I loosened the bolts again. I plan on taking the gears out and sanding them some more to see if that fixes it up before I have to replace them but I was wondering if these plastic/rubber gears don't wind up expanding some over time while soaking in gas all the time. Any other opinions out there before I tear into it again.
  • On mine,
    On the cover and housing that supports the gears on the inside is a black rubber coating on the non-machined areas. This coating was breaking apart and lodging in the gear teeth preventing the motor from turning. I think the reformulated gas has something to do with it. I removed the 'blistered' coating areas and sanded the gears a few months ago. So far, so good.
  • My TH pump had the same problem, and I applied the same fix. Been working fine ever since. Only sand off less than 1/64" at a time....
  • The gas now days damages a lot of plastic/rubber/etc.
    Going to get worse with the 15% ethanol.
    I believe the pumps were not designed for the currant fuels.
  • That seems to be the problem and the fix for most of the problems with the pumps.Try using a belt sander,just put it upside down,lock the power on and sand the gear a little that way.clean it and reinstall.
    You would think a gear that sits in gas would be made better.:h
