myredracer
Jul 10, 2018Explorer II
One solution for cover up the oops could be the tape that is used to cover adjoining sheets of luan wall panelling *if* you can get in a matching color. The tape is about an inch wide.
One easy way to find the backers is by using a magnet. Some folks have used a piece of wood, plywood or even sheet metal to span a couple of studs. You may not have studs if you have a fiberglass sided FW tho.
I like RV Oscar rivets for securing heavy things. They're a type of blind rivet and have a high holding power. They'd work if you use a piece of sheet metal on the wall and then rivet that to the wall and mount the TV to that. Just paint the sheet metal a color of your choice to blend in.
What you do will depend on the size and weight of the TV and whether or not you're using an articulating mount.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
