Mote's avatar
Mote
Repairing the cargo door
Our Cougar has a large cargo door on the side for the pass thru storage like most 5th wheels. The one on the curb side has been had a bubble in it for a couple years. I took the door out yesterday and pulled the panel out of the frame. Looks like the fiberglass (I assume it is) skin has separated from the foam core. Not all of it separated but a 1/3 of it has. I pulled the rest of the panel off the foam board. Looks like water leaked in around the lock area.
Once I get things dried out and cleaned up I'm going to glue the panel back on. Does anyone have a glue they recommend ? I've emailed West Marine to get their ideas as I've used them before when I had to fix some delamination on a previous camper.
  • The people you need to talk with about repairing your delaminated door are
    www.delamrepair.com
    They know what you are talking about
  • Find some construction adhesive that is safe for foam at your big box store. No all adhesives will work as many will dissolve the foam.
    B.O.
  • ksbowman wrote:
    I have 2 new cargo doors w/ frames I ordered for my Keystone Outback just before we sold it. If you PM me I'll give you the dimensions of them if your interested. Never got to put them on.
    Cool, I'll measure the door tonight after work and let you know.
  • I have 2 new cargo doors w/ frames I ordered for my Keystone Outback just before we sold it. If you PM me I'll give you the dimensions of them if your interested. Never got to put them on.
  • Liquid Nails works fine on foam board as probably do any of the construction cements.
  • I was thinking contact cement but very unforgiving. Exterior flooring glue is my other thought. Trowel on and gives a little set time to get it lined up right.
  • The consideration is the foam. What types of adhesive bond to it & don't react with it.
    My first thought would be a contact cement, however offhand I don't know how that would react, if at all, with the foam. Need to read up on that one.
    If West Marine comes back recommending 3M 5200, for Gods sake don't use it. That stuff is plain old nasty for a bunch of reasons. 3M 4200 is much more civilised & bonds well with most material.
  • New baggage doors are readily available. The decals and paint schemes running across the doors not so much.
  • I have used PowerGrab by Loctite to bond hard foam board insulation to aluminum, with great results. I would think it would bond fiberglass and foam also.
    Another option may be a new baggage door, if yours is not something unique. I'm sure a vendor could make one, custom fit, but likely more expensive.
    Jerry
