RAS43 wrote:
No. They have to be pressed into the hub with a larger capacity press. I had a machine shop do mine. And there is a pretty stout snap ring that comes out first.
Not to mention that they are anywhere from $100.00 ( Eastern Marine ) up to $150.00 ( Etrailer ) a piece depending on where you find them.. The number I listed was for the 50mm.. I am sure it can be had cheaper, but not by much....- AnonymousNot applicableNo. They have to be pressed into the hub with a larger capacity press. I had a machine shop do mine. And there is a pretty stout snap ring that comes out first.
- 4x4ordExplorer IIII would just replace the NL bearings with new NL bearings every time I need new tires. Are they not extremely simple to replace?
Veebyes wrote:
Good experience with NLs here. Over 100,000 miles. No problems. That said, I do carry two drums with bearings mounted, ready to to change out at the first hint of problems. Part of the rest stop ritual is to walk around & feel lug nuts on each wheel for excessive heat.
When I had the IS installed on my older KZ, I had MORryde press a sealed bearing into a spare drum and I used to carry that in my storage at all times.. Thankfully I never needed it.- VeebyesExplorer IIGood experience with NLs here. Over 100,000 miles. No problems. That said, I do carry two drums with bearings mounted, ready to to change out at the first hint of problems. Part of the rest stop ritual is to walk around & feel lug nuts on each wheel for excessive heat.
ScottG wrote:
I don't think you can replace NL's with standard bearings. I'm pretty sure you have to replace the axle - which is worth doing in my opinion. I'd rather fix it at my convenience than on the side of the road.
I believe you are correct..
Or in some cases for those of us with the IS, I believe it’s a different spindle...- Have a cousin with a horrible experience with never lube bearings on his trailer. Ruined a trip for him to Colorado. Spent two days trying to get it repaired. I like pack yourself bearings because I can replace seals and hand pack.........never failed me!!
- ScottGNomadI don't think you can replace NL's with standard bearings. I'm pretty sure you have to replace the axle - which is worth doing in my opinion. I'd rather fix it at my convenience than on the side of the road.
- JTracExplorerWe had 7k Dexter axles with the Nev-R-Lube hubs and disc brakes for 6 seasons and over 45K miles. My comfort level was beginning to be exceeded as I know they are never lube but not never fail. I decided to have the MorRyde IS installed, which was done last fall at the MorRyde factory, and while at it changed to the Kodiak hubs and disc brakes. We tend to take at least one long trip every season and I just felt better having something with more readily available parts. I know the downside is maintenance but I added a Hub-O-Meter to help me keep better track of the mileage. So far we are very happy with the new system.
- rugerman1Explorer
Mandalay Parr wrote:
Was checking today and found two out of four slinging grease out into hub.
Just curious why you want to replace a sealed bearing.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
