BB_TX
Oct 22, 2022Nomad
Or if you wanted to continue to use the inside 12 vdc switch as is, buy a relay with a 12 vdc coil and contacts rated to handle the 120 vac and rated current of the heating element, mount it at the water heater, and wire it in the same as if it came with one.
About Fifth Wheel Group
