Just got off the phone with a friend who does sat. installs and he is suspecting a line loss issue as some of you mentioned. He is going to check thinks out after work tomorrow. I hope it's just a connector.
FYI Mike, the connection does have a booster in the wall plate. Frustrating part is there is a separate wall plate labeled "satellite" and I get absolutely nothing from that. I have to connect to the aux. port in the same plate as the roof antenna that has the booster. Obviously some mis-labeling from the factory.
Mark
