NC Hauler wrote:
avvidclif1 wrote:
I'm looking at replacing the sleeper/sofa in mine with theater seating type of recliners. I understand getting the old one out. Stand it on end and straighten it and shove it out the door. Problem is the new one. The old is 68" wide(and that tall when on end), the new is 76" wide.. The door is 68" tall?????
Anyone worked a wider(taller) one in the vertically challenged doorway?
Are you SURE your door is only 68" tall? That doesn't seem high enough for a 5er door. Can you take the couch through the door at an angle? bottom part of couch be at lower left or right hand corner and top part of couch be at the opposite top corner? It'll give you more height, but it depends on how thick couch is....If door is only 68" tall, anyone over 5' 8" would bump their head going in or out....sounds too low.
Just measured mine 5'11". I'm 6'1" and never hit my head.
