- VulcaneerExplorer
up2nogood wrote:
TucsonJim wrote:
It shouldn't take you more than 30 minutes or so. Are you sure you have a motor problem? I thought I did, but it was actually a gear problem in one of the legs.
I agree, had some flat spots on the worm gear, the one I had was not made to remove the worm gear from the landing leg but with a little work got it out, and took it to a machine shop, and they turned it ,and cleaned up the threads, runs great . It is a pretty quick job to replace a landing leg or gear box .
Same with me. Lost some gear teeth. Lippert system. Motor change is easy. Leg removal and replace takes some more tools and a little more work. But not all that bad if you can work with your hands, have a good jack, a couple of 9/16 wrenches. And have reasonable skills. - cummins2014Explorer
I agree, had some flat spots on the worm gear, the one I had was not made to remove the worm gear from the landing leg but with a little work got it out, and took it to a machine shop, and they turned it ,and cleaned up the threads, runs great . It is a pretty quick job to replace a landing leg or gear box . - TucsonJimExplorer IIIt shouldn't take you more than 30 minutes or so. Are you sure you have a motor problem? I thought I did, but it was actually a gear problem in one of the legs.
- donn0128Explorer IIVery easy. If you have Venture mfg landing gear, give them a call and they will sell you what you need. In fact, if you have a Venture Mfg landing gear, it is fairly inexpensive and easy to swap to a dual motor system.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
