laknox
Oct 25, 2018Nomad
3ares wrote:
Has anyone ever tried using a residence refrigerator? If so have you used dry ice for cooling while traveling?
Thanks and happy camping
Lots of people are doing so. Just need to have proper batteries and an inverter to do so. Note, some fridges have restrictions on using in RVs or powering from an inverter. Likely will void warranty, so check carefully. Also, be =very= careful on sizes as some might require removing an entire slide, or a window, to do the swap. Others can fit through the main door, but will likely require removal of the fridge door(s), usually an easy job. You might also have to modify the cabinetry around the fridge, too.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Sep 03, 2026
