Gearitis
Aug 17, 2015Explorer
Yep, fold a towl over the door, also make sure your battery is disconnected, or turn off the inverter in case the inverter has bypassed the disconnect and then take the negative battery post off. The inverter will run the battery to 0. I say this as my dads Silverback was wired with the inverter bypassing the battery disconnect. We fixed that real quick by adding another disconnect at the stock inverter.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
