routemaster
Feb 04, 2018Explorer
John & Angela wrote:burningman wrote:justme wrote:
Most trucks charging voltage to a trailer is fused at 25 amps which is 300 watts. So there is no way the batteries can be kept up to full charge while driving with out the additional charge from solar panels.
There most certainly is! Trucks have or can be retrofitted with rather powerful alternators. You can even order them with dual alternators. The power is there.
All you need to do is run much heavier gauge charge wires, and use a separate heavy duty high current connector for them.
Not to mention, the initial surge of a residential refrigerator may be higher but the fridge itself draws less than 25 amps DC while its running, and that is only about a third of the time. Lots of residential fridges only pull about an amp and a half AC which is less than 20 amps DC even counting for the inverter loss. A truck alternator should have no problem keeping a battery on a trailer while a residential fridge is running in the trailer.
I have just looked at my Magunm panel and it says a start of 10amps and runs at 7amps running our Samsung RF197 is that OK? We are running off solar.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
