We had the "Nocold".
First, I was displeased regarding the fire safety issues: http://www.irv2.com/forums/f54/norcold-circuit-board-fire-hazard-341864.html
Then there is the constant litany of "replace the board", "put a fan inside", "put a fan in the vent stack", "get an aftermarket remedy board for company X" type of fixes.
Now there is an ongoing recall for the plastic door hinges breaking that has been known to the mfr since before 2013, and they still produce it the same way.
We decided early after our purchase to go the residential reefer route. The reefer is a Fisher & Paykel RF170BRPX6 inverter compressor. We would have liked to go with the Samsung model but did not have the clearance for the door mounted handles. On a 29-5K the slide-out closes directly in front of the reefer, and so there is a critical deconfliction area. The F&P has side door recesses as handles, and so it fits well for almost 18 cu. ft.
It uses 3.5A, and I would assume that is during a defrost cycle. You can normally calculate run cycle (from what I have researched) at about 30% of actual time, so for a given 24 hour day, it would have a total of 8 hours of run time. 3.5A is 420 watts at 120V.
We never dry camp; the RV is our "hotel" when we travel. We overnight with full hookups, and the inverter powers the reefer while driving. The 2000 watt inverter is the Magnum CSW2012-X (Pure Sine Wave). The inverter has pass through A/C, automatic transfer switching, and a remote/coached mounted control panel.
After 10 hours of driving disconnected from a/c, our batteries, which are OEM from the dealer (nothing special) never drop below 12.7 volts.
We are exceedingly pleased with the purchase and performance.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
