Toolguy5's avatar
Toolguy5
Explorer III
May 05, 2018
Residential fridge
How can I turn the fridge off Ina 2018 Norh point 387 RDFS.
Can not turn inverter off once shore power is hooked up. The only way I can figure out is to turn off breaker.
  • Cummins12V98 wrote:
    ford truck guy wrote:
    I unplug mine
    Beat me to it!
    Your a Bit slower... its a west coast thing ! :B
  • Go to a dealer in your refrigerator brand and ask how to turn off. The refrigerators he has on display have lights but the compressor is off. My Samsung user manual tell how to do this then warns not to. Telling us the refrigerator brand would help.
  • Mine (Samsung does not) but is turned off by pressing and holding a particular combo of numbers in the thermostat settings. My inverter can be turned off remotely by a switch inside the rig or on the inverter itself. Power also is switched automatically from inverter/shore power and then back to inverter provided the inverter is powered on. Wiring and choices are probably different per manufacturer. If you belong to the Jayco owners forum someone there should be able to answer your question if you don't get results here.
  • djousma wrote:
    My residential fridge has on off on the fridge control panel.
    My does also
  • My residential fridge has on off on the fridge control panel.
  • 2oldman wrote:
    investor? Don't all fridges have an OFF position on the t'stat?
    Inverter
    NOPE
    Circuit Breaker
  • investor? Don't all fridges have an OFF position on the t'stat?
