valhalla360
May 25, 2022Navigator
FootSoldier wrote:
The thought behind trying to get a week on batteries is that I figure we'll be in a hook-up by then. We could go from hookup to another hookup with at least a week in between, I think we could go anywhere we wanted.
If you are going campground to campground, residential makes a lot of sense.
You can make one work but it's not the ideal solution if you do a lot of boondocking away from grid power.
With propane, you can get weeks out of a single 30# tank...no muss no fuss.
Recently, 12v DC fridges have started to be spec'd as standard equipment in RVs. There are pros and cons:
- Biggest pro is the mechanicals are drastically smaller resulting in our new fridge being around 50% bigger.
- We do need solar and an extra battery if we want to boondock.
- It does cool down quicker than a propane (but only issue with keeping ice cream more than a few days in our prior propane units...had to do with eating it not keeping it cold).
12v DC fridges are not a new technology. They have been in use in the marine industry for years. Similar power limitations as RVs but when sailing, the boat is often heeled over 15-20degrees making a propane unit not so functional.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
