Campinfan wrote:
Looks like Cummins12v98 got it to work. Not sure how hard it would be to run 22o to the area...I am not an electrician or a plumber but I am pretty handy. Never saw the gray pipe type setup in the photo before, are those to help prevent leaks or are they backflow preventers?
Mine came prepped with 30A 220V for the dryer. The Washer and dryer amp draw was well within the 30A breaker and wire size. If I had a Bosch dryer the Bosch washer would simply plug into the dryer.
If you are handy it should not be hard to run. I would use 10/3 with ground in 10ga using "SO" cord as it's very easy to bend as needed and is fully jacketed.
