Chickiesky3's avatar
Chickiesky3
Revising gas water heater to electric water heater
Hello,
Totally new to the 5th wheel life.
So I need some help trouble shooting a problem I'm having.
Hot water heater went out in my Alpenlite RV.
I decided to take out the propane heater and put in a 110/120 12 gallon electric water heater.
When checking to see if hot water works, I'm only getting warm water out of the faucet.
What do I check or do to fix this?
  • Check the shower (and outside shower if you have one) to make sure the valves are off and that the water is not just shut off at the showerhead.
  • jdc1's avatar
    jdc1
    Explorer II
    There's a cover on the water heater. Remove it. There is a temperature screw in there, behind the insulation. Adjust the temperature using that screw.
