flifisher wrote:
I towed my fw nose high for 8 years with my 07 dodge without issues. Just blocked the tires to level at the campsite. I was probably 1/4 bubble off a well.
I purchased a 2018 Ram 2500 and had to raise my fw. I moved the springs form under the axle to the top. I was riding 30" front and 18 rear" until the trailer lift. Now it rides level.
I heard someone say you cant reverse the axles if you have equaflex suspension? I suspect the only reason im not having to do anything is because i can lower the truck rear end by 1.5" which helps but its still a bit nose high.
i also heard somwhere that with newer fridges they can be up to half a bubble out and still function fine.
