- rhagfoExplorer III
Me Again wrote:
If you ever drove a semi you would know the dumb people scoot right in on your right side as you set up for a right turn. I had to turn my semi from East bound 1st to Southbound Lincoln Street in Port Angeles all the time and really watch for that.
FWIW I the OP meant for this to be on the thread about blowing out the rear window in the short bed RAM with a 40'11" 5er in tow.
Chris
Well the 40' part explains why he was worried about saving weight on the hitch!
That doesn't really play into how many degrees of turn he has without a slider hitch.
To this post OP's statement, yes right turns tend to be sharper and tighter in the real world (unless in the UK :B). One needs to drive further into the intersection before starting the turn. Left turns just have that naturally.
To this OP's statement, never pull more than about a half a car width from the curb, as some Dumb A$$ with ignore your right turn signal, and try and squeeze around you!!! :S - momentum_rvExplorer
Arcamper wrote:
But they turn faster to the left. I think, right?
Right! or was that correct? Maybe you're right in a left most way. - bigblue1234ExplorerI meant my answer for another reply but instead hit new topic. Sorry for the confusion and it is not snowing in Kansas where I live. But it is cold and maybe my brain got frostbite. Thanks for the replies.
- cbshoestringExplorer II
- gboppExplorer
Me Again wrote:
FWIW I the OP meant for this to be on the thread about blowing out the rear window in the short bed RAM with a 40'11" 5er in tow.Chris
Mistakes happen but, the OP generated a new post, they didn't just respond to the wrong post. - bigblue1234ExplorerYes meant to be on rear window break out in short bed Ram.
- Me_AgainExplorer IIIIf you ever drove a semi you would know the dumb people scoot right in on your right side as you set up for a right turn. I had to turn my semi from East bound 1st to Southbound Lincoln Street in Port Angeles all the time and really watch for that.
Chris - fj12ryderExplorer IIIWell, you do see all those signs on truck about "Wide Right Turns". I always wondered why the trucks turned wider one way than the other. :)
- AllworthExplorer IIIt must be snowing in Kansas again!
- ArcamperExplorerBut they turn faster to the left. I think, right?
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
