Boozecamp wrote:
Another Question. I don't know what rating my wheels are, but they are 16" aluminum on 7,000 lb. axles. I believe the GY 614's need 110 psi. I don't have any idea about my wheel ratings, but can I put GY 614's on my wheels (above) and pressure up to 110?
Are there psi max/ratings depicted on wheels? thanks for the help.
It should be stamped on the inside of your rims, but I would bet since your unit is newer you have the higher rated rims to handle 110psi.
I have experimented around with the pressure in mine. The dealer actually had them aired to 85psi. I moved them up but I still don't have them set on 110psi.
You should be able to get the G614's for around $325 each. That is a lot of money. But it is also a really good feeling towing thousands of miles each year and NEVER NEVER having a blow out or any type of tire issue.
