NC Hauler wrote:
spadoctor wrote:
Only tires I have ever had fail....including your so=called "China Bombs" are Goodyear. My best friend is in the excavating business and every equipment trailer tire he has gotten in 10 years was made in China and no higher failure rate then US made. It depends on use factors more then where they are made.
Big difference in an equipment trailer and a 5th. wheel...What GY failed?...the one's made in China? Marathons? or the GY G614? Which is made in Kansas, (US made)...
We're comparing tires on heavy to heavier 5th wheels, not "trailer tires" that haul equipment...completely different set up....but doesn't matter....
If I'm going with a G rated tire, I'd go G614's, or go with the Sailun S637, (again, I think that is the number)...it'll be a tire I will compare with the G614 when I replace my 5er's tires.
It is the 637---
Here is info off Trailer Tires and wheels site:
637 Specifications
Size LT235/85R16
Capacity Single 3,750 LBS @ 110 PSI
Capacity Dual 3,415 LBS @ 110 PSI
Service Description 126/123 L
Ply Rating 14
Diameter 31.73"
Width 9.25"
Tread Depth 12/32
SKU RS2358516G
Price $205.00 each
add to Cart
