JRMunn's avatar
JRMunn
Roof Leak
I have relocated my father's 2004 Sunnybrook Titan 5th wheel to California's Sierra foothills. We had the first substantial rain a couple of days ago (about 2"), and the roof leaked at the rear of the trailer. I think most of the water came down the driver's side corner where I found it in a wet carpet. After the initial dismay of having to deal with another problem, I took a closer look and have two questions for people that know more about trailers. There is an L-shaped piece of metal screwed into the end of the roof just past the edge of the roof rack that keeps water coming down the sloping roof from running over the back of the trailer. This is just above where water seems to be coming in, and I am wondering if it is a known source of leaks? Also, the interior ceiling and walls are covered with what seems to be a thin wood panel covered with a vernier of formica. Is it possible for water to run down this material without showing and then leaking out at the back of the trailer? Thanks for any suggestions about what needs fixing.
JRMunn
  • Since you are going up there anyway to make a temporary repair, why not do it right and get the job done permanently? I did my Sunnybrook roof seams and penetrations with Eternabond tape when my trailer was around one month old. That was over 13 years ago and it has never leaked one drop since. All you need do is clean very well on either side of the front and back caps where they meet the rubber roof. No need to remove the caulking - just clean it very well. Apply the tape, roll it down and you are done. It will last the life of the trailer and you will not have to worry about any more leaks. :)
    You can see the tape under the coating I put on our roof last year. I painted right over the Eternabond tape. In this area, I used two overlapping strips of 4 inch tape. The best price I found was from the link above. I carry another roll in the trailer for emergency use. Have not had to use it but have given almost half away to others for their emergencies.
    Barney
  • Thanks to everyone for the great suggestions. I hope I found the source of my leak at the driver's side end of the L-shaped metal strip (above the wet carpeting) that I now think must cover a transition from the "rubber roof" to the fiberglass rear cap of the trailer. This strip catches most of the water running down the back half of the trailer roof, before it runs over the back windows, and sends it off to the side, where a small dam is formed by a mound of caulking that extends from the metal piece to a roof rack post. Near the "dam" on the driver's side, I found where caulking along the metal strip has lifted off the roof. My short term solution was to clean the area on and above the metal strip with a stiff brush, blow it off with compressed air, and then spray a can of white Rustoleum Leak Seal along its edge - with extra attention and amount given to the area where I think the leak was coming from. This provides a penetrating, waterproof covering that I hope will stick for the rest of the winter. If the leak continues, I will move on to the suggested pressure test and also try a layer of sealing tape. If this patch does stop the leak over the winter, then I can pull the metal strip off next summer, when all will be dry, and fix it right - including use of sealing tape once the mounds of caulking are removed from the many screws. Thanks again.
    JRMunn
  • Front and rear seams always leak eventually.
    Go get some 4" wide Eternabond tape and seal the front and rear seams with it.
    You will never have a leak there again.
  • Pressure test is the best way to determine source of leaks - they cost about $100. Not familiar with L your referring to - might be someone placed it there to mitigate known water problem - if so lousy fix. Check the roof caulking everywhere the actual source of the leak may not be in the vicinity of the wet carpet (water maybe entering from different location and traveling along the interior of the ceiling cavity). Water leaks are PIA and if not fixed quick can result in expensive repairs - don't ignore.
  • A seal test is a means of pressurizing the RV to test for leaks. You apply air to the inside of the RV by using the leaf blower usually through one of the roof vents. You then use soapy water along all joints, windows and seals to see if air is leaking via soap bubbles.
    You might check YouTube for a video on how to perform one. A quick check of the forums here didn't produce anything but I remember reading how to do it before.
    On a side note, did a factory tour of the Coachmen facilities this summer and at least on the TT line they did a seal test at the end of the line. Every unit got tested before it left the building.
    Good luck, John
  • Sorry for my inexperience, but what is a "seal test"? And how would a leaf blower be used to find leaks?
    JRMunn
  • I had that same kind of strip along the back of our last TT. It didn't ever leak but I was suspicious of what ever thin sealant they used. I ended up putting a piece Eternabond tape all the was across to cover it.
  • Water can ru a long ways. There is only o e way I know of to positively identify leak spots. That is with a seal test. As an alternative you can try a leaf blower.
