Tell me what you think... The roof on my 2014 Keystone Laredo 292RL pulled loose from the trim that holds it down in front. Doesn't look like it will be covered by warranty - we're just outside of...
Would be nice to see a photo so we can be sure to give you the best advice we can! Sounds like the EPDM pulled back from the front cap trim? I would remove the trim, put new butyl putty tape down, new screws with a good polyurethane sealant, then cover the entire front trim strip with 4" Eternabond! I have done that to every rig I have had so far! Good luck!
PS...if the EPDM is loose you may need to also glue it back down.
