joebedford's avatar
joebedford
Nomad III
Jun 13, 2022
roof repair?
I have a Voltage 3950 and I've noticed a soft spot on the rood. It's about even with the back end of the living room slide. There appears to be a 5" long slice in the rubber roof in the middle of the soft spot. I looked at it before and thought only the white part of the roof was cut but because of the soft sport and a 3" circle showing some water damage on the inside, I guess it's through to the wood. I must have hit a branch or more likely a branch fell on the rig.
Anyway, I'm wondering if I need to cut the rubber roof to remove the soft plywood OR if it's OK to glue a 2'x2' 1/4" piece of plywood over the soft spot then seal it with white stuff. A 2' square should be enough to straddle two roof ribs.
  • jdc1's avatar
    jdc1
    Explorer II
    If you attempt to repair it, do it the correct way. Cut the roofing material 4-6" past the affected area. Cut our as little plywood as possible. Reinforce the cross section with flat 2X4's at each end, being sure you slide the lumber under the existing plywood. Use screws, not nails (they hace 3X the holding power). Add the new plywood. Screw it all down, including the edge of the existing plywood. Cut the new roof material larger than the piece you cut out. Glue it in place. Use Eternabond tape on top of the new roofing material, to ensure permanent adhesion (Eternabond tape is a real pain to remove).
  • jdc1's avatar
    jdc1
    Explorer II
    griffy00 wrote:
    They make a rubber roof repair tape that can be found at most RV part centers.Just a thought to stop further moisture damage.
    Eternabond.
  • They make a rubber roof repair tape that can be found at most RV part centers.Just a thought to stop further moisture damage.
