RetiredSquid's avatar
RetiredSquid
Roof top ac require 50 amps?
Yesterday when I picked up my new fifth wheel, I had an orientation and the gentleman giving it was showing me the adapters from 50 amp 2 30 amp to standard household receptacle. He told me that if I didn't have it plugged up to 50 amp that I would burn up my AC unit????
I don't know what to think about that, I use a generator to provide power to my 25 year old Southwind Motorhome and it hasn't seemed to affect the air conditioners on it???
  • Appreciate answers, so next question is if i buy a new portable generator what should i look for. Unfortunately if I want water from my well on my boondock property in northern michigan I need 220v.
  • Just make sure that the plug is 30 amp with 120 volts. Some dryer plugs run 220 volts and have a similar looking "30 amp" plug. Many people have fried their equipment plugging into that plug.
    Old Bisquit above has all that you need to know.
    Also former squid.
  • 50A 5th wheel with a 15K A/C Unit
    I can operated it on:
    50A power supply
    30A power supply
    20A power supply
    ALL are 120V AC.......
    Biggest issue is 'voltage' of power supply
    108V and I shut down my A/C Unit cause I personally do not like to operate induction motor on less than 108V (if that low I run generator which is 30A)
    Course there are limitations on each CB Amp Rating
    50A.........pretty much can run everything in 5vr on 'electric'
    30A.........might have to swap fridge/water heater over to propane
    20A.........A/C Unit and converter. (Did that for over month one time)
  • The gentleman was uninformed. You can run your AC on a 30 amp power source. If you have two AC units you will want to only run one of them at a time unless you have a good power management system. I would avoid trying to plug into a 20 amp circuit, just to many "Maybe's".
  • My 50 amp service 5er is currently plugged into my home 120v 30 amp rv receptacle / plug on a 30 amp breaker and I can run both ac's with no problem. Its over 90 degrees outside as I write this.
    Also when camping in many state parks 30 amp is the highest amp power available and I run 1 ac with no problem & the hot water heater and microwave.
    I have also run 1 ac on 20 amp service with no problems in the past.
  • It is hard to fathom, but so many RV sales people and even worse, technicians are so ignorant about RVs and electricity.
    It is possible to run ONE RV A/C on a 20 amp circuit, provided there is nothing else on the circuit and the A/C is the only thing on in the RV and the extension cord is not too long.
    Ken
  • Well I would say that is likely incorrect. Does your 5er have an energy management system? How many AC units? What is the start-up amp draw of the AC(s)?
  • It's a shame that some people doing this don't have a clue. There probably won't be a problem if the batteries are charged and nothing else is running. I run my AC at home on 20 amp circuit and don't have a problem.
