Old-Biscuit
Oct 06, 2014Explorer III
Single motor drives BOTH sides equally......
So if both legs are not touching ground after dropping inner tubes then one leg assembly will start lifting trailer before other takes some load. This can cause twisting of frame and failure of landing gear leg (shear pins/drive gear/jam nut)
Best to have both touching ground prior to extending (raising 5vr)
Shovel to dig out highside, small thin blocks for shims OR adjustable foot pads (Winfield RV Products)
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
