laknox
Oct 06, 2014Nomad
Personally, I level side-side, pull the pins on the landing leg extensions, let 'em hit the ground, then power the legs down until the pins snap back into place. I've never been on a spot so unlevel that I felt I had to shim one side over the other. Any twist to the frame is so minor that I doubt I could even measure it. All I do is to put a spare lego block under the feet to spread the load a bit. (shrug)
Lyle
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
