whiteeye42 wrote:
when i dropped one of mine out to replace it i hooked it up to the truck raise the landing gear up as far as i could and the dug a hole about a 2 feet deep or so under the leg dropped the old one out and put new one in no big deal
 you say your is on the back side of the leg do you have a hole on the outside of the leg to be able to move the pin from the back to the side i would look before moving anything
Thanks for the input.  That is kinda what I had in mind about digging a hole and yes, after looking at it I shouldn't have an issue with mounting holes.  It appears that it will work fine when rotated.
Steve
