sdfiver wrote:
4X4FF;
Our new 5th came with factory installed JT Strongarms. Unless the aftermarket kit is different from the OEM kit I'd say your landing gear legs are correctly oriented for the Strongarms.
The lower arms attach to the back of the legs with the nut on the front of the leg. You'll have to enlarge the lowest hole to 1/2" for the through bolt if it's not that size already.
You may have to move your 5" fence post sewer holder as the arms may hit it when you have the gear retracted. Hard to say from your pictures.
Ours has the Snap-pins facing forward by the way.
It would be easy to swap the snap-pins to the front. That might be my simplest option. I already planned on moving the sewer hose holder back quite a bit.
Steve
