- freewayrandyExplorerAfter flushing everything, smell is gone. Thanks for all the help.
- SamsonsworldExplorerI have to flush and bleach the heck out of my tanks sometimes.
- 2112Explorer III believe the zinc anode rod is better for eliminating the rotten egg smell
BB_TX wrote:
freewayrandy wrote:
Maybe I'm an idiot but can't quite see how battery water level affects my water supply.
It doesn’t. If you only get the smell when you run water then it has something to do with your water system. Or park water. See if it has odor coming out of the park faucet.
I'm the only one out of 5 in our group that had the smell so not the park water. So must be my system. Yesterday, drained water heater, flushed it, lots of white crud came out, put in new anode rod. Sanitized fresh tanks, 1/4 cup bleach per 15 gals. Ran all taps to get solution thru entire system. So far no egg smell. Run more today then drain and flush again. - Turn off water heater, turn off water, remove plug or anode from water heater and drain the tank (unless you have a valve to do so). Replace plug/anode/close valve, and refill the tank with water.
Trying to flush it out by simply running good water into 10-12 gallons of smelly water will take forever. - midnightsadieExplorer IIWELL did you find the problem? lot good answers.
- Retired_JSOExplorer IIHappens when minerals react if WH is not used for a few weeks either with or without anode rod. If on full hookups just run water through water heater for 20-30 minutes and the smell will go away.
- SkibaneExplorer II
lhenry8113 wrote:
House battery burning up-check water level.
If they're low on water, also check the voltage they're being maintained ("floated") at - If it's more than 13.8, you've got a problem with the house battery charger. - BB_TXNomad
It doesn’t. If you only get the smell when you run water then it has something to do with your water system. Or park water. See if it has odor coming out of the park faucet. - freewayrandyExplorerMaybe I'm an idiot but can't quite see how battery water level affects my water supply.
About Fifth Wheel Group
