- lhenry8113ExplorerHouse battery burning up-check water level.
- midnightsadieExplorer IIyep sounds like your batteries are boiling smells like rotten eggs.
- corvettekentExplorerIf you have flooded lead acid batteries, you should check the water level.
- freewayrandyExplorerWe were at an RV park and no one else had the issue. I've changed my filters to no avail.
- BB_TXNomadSome who have clothes washer hookups but no washer have reported a bad water odor over time due to stagnant water in those water lines. Solved it by adding cutoff valves in the pipes near where they branch off from the main lines.
- mleekampExplorerMost likely from the well. Sulfer (rotten egg smell) and iron are the two most common elements in well water. We have a well at home, and have filtration to eliminate it inside the house. Filling our RV tank from home, or using water from the campground, the filters built in do help.
I suggest buying a filter set up to add to your city water hookup. Should do the trick. - way2rollTrailblazerCould be a lot of sulfur or iron oxide in the water. Some bacteria live in iron rich water.
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
