Last fall, I installed a set of Sailun tires on my Montana, upgrading to G rated tires. I’m running only 90-95 pounds in the tires. They are shaking the camper quite a bit. Last week, we cravked th...
It’s the darn roads! Governments spend infrastructure money where th e votes are. The closer to the big city the better the highways. Having had several trailers and fifth wheel cargo trailers too I highly recommend if you are going to switch out your axels go to 7000 lb. 0 degree Torflex axels. Far smoother ride. Buying new...insist on them.
