gbopp wrote:
I think eventually a section may pull loose and allow air under the rubber. If that happens, especially along the front, it could tear the roof off.
I would take the time and reglue the rubber to the roof. It may save you a lot of work/damage in the future.
Check Youtube, there should be several videos explaining the repair.
And maybe it will just billow and never tear off? Do you feel lucky :@
I can't see it saving anything except the cost of the sheet of epdm. Same amount of labor involved. If anything, I'll slit it some where it seems most loose and eternabond the slits.
