wantabe351
Aug 31, 2016Explorer
Except to run the AC, there is no reason to run the Generator...If your running it for the heater just buy 2-6v Batteries and you will have no problems of sleeping throuht the night, most rv's have the capacity for 2 or more batteries, 2-12v batteries might work but the 6v battery has the bigger plates to last a longer drain period, like using the heat...wakeup in the am fire up the gen make coffee and give the batteries a 1 hour charge..Let me tell you that with 4 6v golfcart(G2) batteries and a 250w solar panel and except for the AC its what generator!..on a 1 month rv trip my gen ran for 6hrs, mine is a built in gen..you dont need the solar, if your traveling the truck should charge them up if you have the 7pin pigtail camper to truck. If not run a 10awg wire battery to battery with a 30amp relay so it wont run down the truck battery when truck is off...
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
