schlep1967
Oct 13, 2020Nomad
hilke40 wrote:
If you have the single handle to by pass , that is probably not your problem. When they went to the single handle bypass method, they put a one way check valve on the top line of water heater. It is letting water back into heater, which it should not be doing. They are around ten bucks and just screw off, after you remove the water line.
What he said.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
